Actual Rolling Diameter Question
Pedal4life
San Diego, CA US
Edited Date/Time 11/15/2017 11:55am
Some of the current 27.5 tires have so much sidewall/volume they really look close in size to a 29 but how close are they really?
Falcon
Menifee, CA US
11/15/2017 11:53am Edited Date/Time 11/15/2017 11:54am
They don't do bicycle tires the same way car tires are sized; in other words, width/sidewall height as percentage of width - diameter of wheel, so you'd have to get freaky with some math and the Pi constant. Since I'm no math whiz, I'm not about to do that. However, I do know that the Pivot Switchblade is made to accept a 27.5+ wheel OR a 29. I don't think there are even any frame adjustments, although I could be wrong. Therefore, the rolling diameter must be very close.
Pedal4life
San Diego, CA US
11/23/2017 4:25pm
We’ll definitely not looking for anything difficult just line the valve stem with the ground, mark the ground & then roll until valve stem is @ the ground again this from 2 of my tires there fully inflated the 1st is.
Maxxis Minion DHF 27.5x2.5wt 87.375” or 221.932cm
The 2nd tire is
Maxxis Minion DHR2 27.5x2.3 86.5625” or 219.868cm
Jsmith
MT US
11/24/2017 3:43pm
I just rolled my 29 DHF 2.3 and got 91.375". That was on a stans flow ex at 26 lbs..
'size
AZ US
11/24/2017 4:06pm
Pedal4life wrote:
We’ll definitely not looking for anything difficult just line the valve stem with the ground, mark the ground & then roll until valve stem is @...
The 2nd tire is
i hope those tires aren't mounted on the same bike at the same time. without equal rolling distance who knows what's going to happen, but i'm sure it's nothing good.
Pedal4life
San Diego, CA US
11/30/2017 5:22pm
The 2nd tire is
'size wrote:
i hope those tires aren't mounted on the same bike at the same time. without equal rolling distance who knows what's going to happen, but i'm...
Yes there both on the same bike & running 1-2 10th’s of a inch difference front to rear is fairly common & on this bike it’s truly incredible how it corners massive grip & great speed, I went further with the front to rear differences with a narrower rim on the back also so as to keep tire profiles in the proper shape.
Building a collection of rolling diameter would be great for all of us
'size
AZ US
11/30/2017 6:50pm
Pedal4life wrote:
Yes there both on the same bike & running 1-2 10th’s of a inch difference front to rear is fairly common & on this bike it’s...
i was being sarcastic at the idea of two tires rolling different distances on the same bike, not their widths. guess you had to be there.
11/30/2017 7:53pm
Now that's funny!
Post a reply to: Actual Rolling Diameter Question
