A cheaper high pivot idler pulley
_Lan
AO
Edited Date/Time 4/3/2022 1:50am
The idler on my bike needs replacing and they are pricey for what they are. I tried finding a cheaper solution and came across fixie sprockets. It seems possible to design a carrier for it. This is my interpretation that requires a bb tool and a chain wrench to install. Will still need to produce one to try but I feel it's feasible. Only maybe 30-60 grams heavier than an aluminum pulley. You also get a choice of 12T to 22T or whatever number of teeth can fit on your frame to change your anti-squat numbers.
Cheaper, lasts way longer, and more variable to boot. I don't see any drawbacks besides the weight. Is there anything I'm not seeing?
11/4/2021 10:53pm
From the rendering it looks like it would be significantly wider than a standard pulley. Could there be frame compatibility issues (or potentially chainguide compatibility issues) because of the increased width?
Cool idea, though. I think you should prototype and try it if you can!
_Lan
AO
11/5/2021 3:08am
From the rendering it looks like it would be significantly wider than a standard pulley. Could there be frame compatibility issues (or potentially chainguide compatibility issues)...
Yeah, need to make sure it clears the crank arm and frame. Will be 3d printing one for testing as soon as the sprockets I ordered arrive. It should be an easy fix though, just make the lock ring thinner etc.
it's for my own bike design so I'm able to make changes to make it fit. Just thought I'd throw the idea out there so other people can try it out on their own. I based this on the forbidden 16T pulley that I'm using that is nearing the end of its life.
Diag
11/5/2021 3:32am
Since there's no torque transferred trough the idler you could get rid of the jam nut to reduce the width, the sprocket just needs to be tight on the axle so it doesn't back of with vibration... Cool project, keep it up!
Grand Junction, CO US
11/5/2021 6:56am
Diag wrote:
Since there's no torque transferred trough the idler you could get rid of the jam nut to reduce the width, the sprocket just needs to be...
I'm kind of an idiot but what do you mean there is no torque transferred through the idler? This seems wrong.
Norristown, PA US
11/5/2021 8:10am Edited Date/Time 11/5/2021 8:19am
unless things have changed in recent years, cogs for track bikes are designed for single speed chains, and are too large to work with chains for geared drivetrains. geared chains (9/10/11/12spd) are too narrow and likely will not properly mesh with the teeth on a track cog.
edit: it seems like 3/32 track cogs are widely available, and might work with certain geared chains. a 1/8" track cog will not work.
Norristown, PA US
11/5/2021 8:11am Edited Date/Time 11/5/2021 8:21am
i have a track cog at home (although it might be a 1/8" size) and some 9 & 11spd chains, I can check when i get home from work if you'd like.
millsr4
Bellingham, WA US
11/5/2021 11:59am Edited Date/Time 11/5/2021 12:00pm
I think Diag means that no torque goes through the idler in the opposite direction of the ID threads so just the carrier without the nut would suffice. Just like how there is no nut on a single speed hub with a freewheel.
Diag
11/5/2021 2:00pm
I know it is somewhat counter intuitive i'll try to explain : the idler is freely spinning on a shaft, it cant transmit twisting force to the frame, and the torque created by the part of the chain going the crankset is cancel by the torque created by the part of the chain going the the wheel (same magnitude, opposing direction)
Idlers are called idlers because they dont create or consume power, they just redirect force.
Maybe I should me more precise too, there is no torque transferred around the axis of the bearing when the speed is constant (granted the acceleration in this case are probably small and can be ignored)
11/5/2021 2:16pm
Diag wrote:
I know it is somewhat counter intuitive i'll try to explain : the idler is freely spinning on a shaft, it cant transmit twisting force to...
Ah ha! This makes sense. Thx!
_Lan
AO
11/6/2021 12:17am
I thought about that. Should save a bit of weight as well hah.
11/9/2021 9:46am
Why the double BB interfaces? Just make the sprocket carrier a flanged single piece part and deal with disassembly from the NDS ('internal') side if crank clearance is a problem. Just rotate the sprocket assembly with the bearing around the vertical axis on the bolt and you're done. And make the outer flange thinner if needed.
As for sprockets, you have HG splined single speed sprockets as well. A few strategically placed keys should do the trick without needing any threads. And the whole assembly will be thinner still Wink
If you need HG freehub/sprocket dimension, PVD posted some drawings here: https://www.mtbr.com/threads/question-on-shimano-9-speed-rear-casette-s…
slimjim22206
Barrington, RI US
1/18/2022 7:31am
_Lan wrote:
[img]https://p.vitalmtb.com/photos/forums/2021/11/04/11595/s1200_idler.jpg[/img] The idler on my bike needs replacing and they are pricey for what they are. I tried finding a cheaper solution and came across fixie...
Hey! I was just wondering what CAD program you used? You nailed the CAD not gonna lie
1/18/2022 7:50am
Looks like Solidworks.
I did just now notice the shape of the teeth. It's... interesting. Is it just a placeholder as a standard sprocket will be used?
If anyone will be drawing some sprockets, here's a guide: http://www.gizmology.net/sprockets.htm
slimjim22206
Barrington, RI US
1/18/2022 7:54am
Looks like Solidworks. I did just now notice the shape of the teeth. It's... interesting. Is it just a placeholder as a standard sprocket will be...
It does look like solid works. And thanks for the link. Always wondered how to do that.
1/18/2022 8:19am
As long as we're nit picking, I just noticed that the lock ring has no threads. Not that I have any clue how to use Solid Works.
JankyEric
Bellingham, WA US
3/6/2022 11:57am
Solid design! I made and sold a bunch of these idler pulleys for Forbidden bikes using a SRAM 16t chainring. I've just sold out of them and was thinking about a similar design for my next batch.
https://jankcomponents.com/products/steel-idler-pulley-kit-forbidden-dr…
_Lan
AO
4/1/2022 8:47am
Finally had one made. Using a 3/32 surley 15T sprocket. Works as intended.
4/1/2022 9:21am
Is that an updated Mk1 frame or an Mk3? Tongue
idkmtb
Tilton, NH US
4/1/2022 10:25am
_Lan wrote:
Finally had one made. Using a 3/32 surley 15T sprocket. Works as intended. [img]https://p.vitalmtb.com/photos/forums/2022/04/01/12331/s1200_IMG_20220401_122505.jpg[/img]
wanted to make sure you were aware, looks like your link pivot is cracked
4/1/2022 12:29pm
Talk about being an eagle eye...
_Lan
AO
4/2/2022 11:42pm
Lol, made me check the bike. Fortunately that's just a strand of teflon tape.
_Lan
AO
4/3/2022 12:03am
Also, sprocket loosens over time. Guess I'll need to put loctite on it
4/3/2022 12:41am
Or make everything aluminium so it seizes up like the bolts on a DUB crank :D
4/3/2022 12:47am
Apparently a third frame, a MK3. The op didn’t reply, but he just posted a bike check of a MK3. Smile
_Lan
AO
4/3/2022 1:39am
mk3 is the updated mk1 haha.
Still some problems despite changing suppliers. Really have to be there in person to guide the work to get what you want. Language barrier is a problem too. Bike is very usable though despite the flaws. Hopefully it's strong enough and I'll be able to enjoy it for a long time.
_Lan
AO
4/3/2022 1:40am
built in thread locker Grinning
_Lan
AO
4/3/2022 1:50am
Just had the first ride today. Checking for bolts unthreading and signs of failure while hitting bigger and bigger huck to flats. Not to the point of bottoming out mind, still don't fully trust the bike. Really love how the bike feels so far.
illoaminati
London, ON CA
12/10/2022 6:47pm
Is there any way to get a hold of one of these carriers?
I’m fed up with the labyrinth seal on my Druid. The NSB SS idlers have been sold out forever, and the Jank carriers are nowhere to be seen(good luck on PB Academy Eric!)
Post a reply to: A cheaper high pivot idler pulley
