SOLD please delete
astrizzle
Moscow, ID US
3697th
Edited Date/Time 8/18/2014 12:43pm
This is a slightly used 2011 Cannondale Claymore size Medium. This has been ridden only 1 season (less than 10 times) and has been well taken care of by a bike shop mechanic. Only 2 small scratches and NO dings or dents, it even has protection tape to prevent cable rubbing.
This bike is truly 2 bikes in one!!! Just flip the switch and it’s a DH machine with 180mm of travel and then flip the switch again and it’s a rock solid rear end with 110mm that helps you climb like no other 7 inch travel bike can climb, you'll be surprised how much you use it. The build on this bike is completely custom to help balance lightweight and durability and all claymore frames are the same.
There is a BUNCH of brand spanking new parts on this baby as well! (I was planning on riding this bike a ton this summer but I have to scare up some cash for my car to get fixed). The rear wheel's parts are used but it’s freshly built and hasn't even been ridden on the dirt but has brand new spokes and nipples!!
Another cool thing about the frame is that it also has geometry adjustability along with its travel adjustability; meaning you can lower the bottom bracket height by slightly more than a half inch and rake out the head angle a little bit also for those DH days and then raise it again for the XC days. Buyer pays for shipping/boxing (usually $100 total depending on where it is being shipped) and I will only use PayPal unless you are a local pick up with cash or certified check. Message me if you have any questions, thanks for checking it out folks! The Price is $3200 USD and I will ship anywhere within the USA, no lowballers please.
Parts:
Frame: 2011 Cannondale Claymore Size Med Blue/Black/White
Fork: 2011 Fox 36 TALAS 180mm/140mm
Shock: 2011 Fox Dyad 180mm/110mm
Crankset: Sram BB30 X1400
Pedals: Deity Decoy LT Black w/ Red pins
Tires: Maxxis Minion DHR 2.25’ wire bead BRAND NEW
Chainguide: Bionicon Mini Guide BRAND NEW
Cassette: Sram 11-34T 10 Speed BRAND NEW
Chainring: Sram 38T
Rear D: Shimano XT Med Cage 10 speed BRAND NEW
Rear Shifter: Shimano Zee 10 speed BRAND NEW
Front D: Shimano SLX 2 Speed BRAND NEW
Front Shifter: Shimano Rapid Fire BRAND NEW
Stem: Cannondale S1
Handlebar: Sunline V1 low-rise 745mm wide Silver
Grips: ODI/Race face Sniper lock-on
Brakes: Shimano XT BRAND NEW
Seatpost: Crank Brothers Cobalt 20mm Offset BRAND NEW
Saddle: Cannondale S1 Black
Chain: Shimano 10 Speed BRAND NEW
Rear Hub: 142mm Industry Nine Gold (Recently Serviced)
Rear Rim: DT Swiss EX 5.10
Front Hub: DT Swiss (Specialized)
Front Rim: Mavic 729
Extras: High Volume Shock pump, Red Pins for the Pedals, Used MRP Chainguide (in case you want to go single ring), Shock Manual.
Post a reply to: SOLD please delete
