2012 DEMO 8 II
bobbyboka
Lancaster, CA US
Edited Date/Time 8/16/2014 7:49pm
HI!!! I have a M demo 8 II 2012 down hill bike one of the best down hill bikes on the market right now the bike is very light for a DH bike and could hold up to any rider even sam hill!!!
Im selling it due to injury!!the bike is ALL STOCK . beside a red shift cable!! i rode the bike a few times i love it. contact me if you want it
661 six zero nine 5534 call or text!!
DONT MISS OUT!
4,000
FRAME
M5 manipulated alloy, compact race design, 1-1/2" forged HT, magnesium link, ISCG 05 mount, cartridge bearing rear shock mount, rear derailleur protector, 200mm travel
REAR SHOCK
Cane Creek Double Barrel, coil over w/piggy back, high/low speed compression and high/low speed rebound, 9.5x3", XS: 300, S:350, M:400, L:450
FORK
RockShox Boxxer World Cup, Mission Control damper, alloy steerer, low/high speed compression and rebound adj. w/ bottom out control, 20mm Maxle DH thru-axle, 200mm travel
HEADSET
1-1/2" integrated for 1-1/8" steerer, cartridge bearings
STEM
Specialized Direct-Mount stem, 40mm length, 31.8mm, 4-bolt, forged
HANDLEBARS
Renthal Fat Bar, 780mm wide, 7º backsweep, 31.8mm
GRIPS
Specialized lock-on, S/M: Grappler, Others: Grappler XL
FRONT BRAKE
Custom Avid Code X0 World Cup, hydraulic disc, tool-less reach, Code caliper, semi-metallic pad, stainless hardware, 200mm rotor
REAR BRAKE
Custom Avid Code X0 World Cup, hydraulic disc, tool-less reach, Code caliper, semi-metallic pad, stainless hardware, 180mm rotor
BRAKE LEVERS
Custom Avid X0, carbon blade, tool-less reach adj., w/MatchMaker clamp
FRONT DERAILLEUR
REAR DERAILLEUR
SRAM X0 DH, 10-speed, short cage
SHIFT LEVERS
SRAM X9, 10-speed, trigger, w/MatchMaker clamp
CASSETTE
SRAM PG-1050, 10-speed, 11-26t
CHAIN
KMC X-10, 10-speed, w/ reusable Missing Link, nickel plates
CRANKSET
SRAM X0 DH, carbon arms, single ring, PF30 spindle, 165mm, w/Gamut P-30 chainguide
CHAINRINGS
36T thin alloy
BOTTOM BRACKET
Custom SRAM PF30 DH, 83mm shell
PEDALS
Specialized Benies, low profile with removable pins
RIMS
Roval DH 26, 30mm wide w/eyelets, 32h
FRONT HUB
Specialized Hi Lo disc, laser-etched logo, sealed cartridge bearing, 20mm thru-axle, 32h
REAR HUB
Specialized Hi Lo disc, 150mm, hollow 12mm Cr-Mo axle w/ RD guard, 32h
SPOKES
DT Swiss Competition 2.0/1.8/2.0mm stainless
FRONT TIRE
Specialized Butcher DH, DH casing, wire bead, soft dual-compound, 26x2.3"
REAR TIRE
Specialized Butcher DH, DH casing, wire bead, soft dual compound, 26x2.3"
INNER TUBES
Presta valve 26x2.4/2.75, 2.25mm thick
SADDLE
Specialized DH, 8mm hollow Cr-Mo rails
SEATPOST
Thomson straight w/ 12º clamp, 367mm
bobbyboka
Lancaster, CA US
6/21/2012 11:52pm Edited Date/Time 4/21/2016 10:21am
some pics
Post a reply to: 2012 DEMO 8 II
