2011 Cannondale Claymore Med in GREAT condition!!
astrizzle
Moscow, ID US
3697th
Edited Date/Time 8/18/2014 7:59am
This is a slightly used 2011 Cannondale Claymore size Medium. This has been ridden only 1 season (less than 10 times) and has been well taken care of by a bike shop mechanic. Only 2 small scratches and NO dings or dents, it even has protection tape to prevent cable rubbing. This bike is truly 2 bikes in one!!! Just flip the switch and it’s a DH machine with 180mm of travel and then flip the switch again and it’s a rock solid rear end with 110mm that helps you climb like no other 7 inch travel bike can climb, you'll be surprised how much you use it. The build on this bike is completely custom to help balance light weight and durability. The parts that are brand new on this bike are: Maxxis Minion Tires and 11-34 Sram Cassette. The rear wheel's parts are used but its freshly built and hasn't even been ridden with brand new spokes and nipples!! The frame also has geometry adjustability along with its travel adjustability; meaning you can lower the bottom bracket height by slightly more than a half inch and rake out the head angle a little bit also for those DH days and then raise it again for the XC days. I am only selling this bike because I believe it is smidge too small for me. I will ONLY trade for a Giant faith 2010 or newer and it MUST be a size LARGE, anything else I"m not really interested in so please don't message with other offers, thanks. The bike comes with a high pressure, shock pump, extra pins for the pedals and chainstay protector, buyer pays for shipping/boxing (usually $100 total depending on where it is being shipped) and I will only use Paypal unless you are a local pick up with cash or certified check. Message me if you have any questions, thanks for checking it out folks! The Price is $3200 USD and I will ship anywhere within the USA, no lowballers please.
Parts:
Frame: 2011 Cannondale Claymore Size Med Blue/Black/White
Fork: 2011 Fox 36 TALAS 180mm/140mm
Shock: 2011 Fox Dyad 180mm/110mm
Crankset: Sram BB30 X1400
Pedals: Deity Decoy LT Black w/ Red pins
Tires: Maxxis Minion DHR 2.25’ wire bead
Chainguide: MRP G2
Cassette: Sram 11-34T 9 speed
Chainring: Sram 38T
Rear D: Shimano SAINT Short Cage
Rear Shifter: Shimano SAINT rapid fire
Stem: Cannondale S1
Handelbar: Sunline V1 low rise 745mm wide Silver
Grips: ODI Race Face custom lock-on
Brakes: Avid Custom XO (Carbon Elixir levers/Code Calipers)
Seatpost: Cannondale S1 Black
Saddle: Cannondale S1 Black
Chain: Sram Stainless steel
Rear Hub: Industry Nine Gold (Recently Serviced)
Rear Rim: DT Swiss EX 5.10
Front Hub: DT Swiss (Specialized)
Front Rim: Mavic 729
Post a reply to: 2011 Cannondale Claymore Med in GREAT condition!!
