2010 Trek Scratch Coil
traeday
Altamonte Springs, FL US
Edited Date/Time 8/16/2014 7:30pm
2010 Trek Scratch Coil (9)
2010 Trek Scratch 9 Custom- 17.5" ( virtual large)
Fitment - I am 6'1" and it is perfect
Custom build - in Excellent Condition!
Pedalable Freeride? YES you can pedal this bike to the top of your favorite
ride without feeling like you are riding a pogo stick, but turn the trail
downward and this bike rocks, the rougher and bigger the better, it will not
disappoint!
$2500 Email (traeday @ aol dot com) or Text or Call (four zero seven) four four 8_3376
I was not a fan of the baby blue on the Scratch 9 so I got the Scratch Air 6
frame (same frame different color scheme) and built it similar to the Scratch 9.
The 180mm front fork is a better match to this frame (a 180mm travel fork comes
on the 2011). The stout front fork and the RC4 rear shock make the bike so
stable on landing drops and took my riding confidence to a new level.
The bike isn't getting ridden enough, it is in EXCELLENT condition for a
freeride bike.
The frame has some small minor - general use scratchs. The major skuff areas
were covered with automotive protective film. Bike has no crashes, everything is
straight and true. Rear cassette needs replacing, ring 7 and 8 pretty used.
Would have done it but I felt the next owner of this great bike could pick what
they want on it
Love this bike and will miss it, but need money
Adjustable Geometry: By inverting the two "mino" links at the rear of the EVO
link,
you can choose between 66/72 and 66.5/72.5 degree head and seat tubes.
Selling for $2500 plus shipping
The 2010 Scratch 9 Retailed for $5900
The 2011 Scratch 9 Retails for $5770
* Color: Gloss Black, gold/white accents
* Frame: 17.5" Alpha Red Aluminum w/ABP, Full Floater, alloy EVO Link, E2
tapered head tube, oversized pivot bearings, ISCG03 mounts 142X12mm or 135x12mm
rear axle, replaceable derailleur hanger, adjustable geomety, 170mm Travel
* Fork: 2010 Rock Shox Totem 2-step air Fork 180-140mm 40mm upper tubes, Mission
Control features externally adjustable rebound, separate low-speed and
high-speed compression damping and a Floodgate On/Ofl lockout, tapered steerer,
2Step lever will decrease fork travel by 45mm for easier climbing, Maxle Lite FR
QR thru-axle 20mm
* Shock: Fox DHX RC-4, custom "gravity tuned" w/externally adjustable velocity
sensitive damping, bottom out force adjust and bottom out progressiveness,
external rebound;
8.5 x 2.5" with 450 lb spring
* Wheelset: Bontrager Cousin Earl Elite Disc wheel system, 6 bolt , tubeless
ready
* Shifters: Shimano Saint integrated shifter/brake lever
* Disc Brake Calipers: Shimano XT
* Disc Brake Rotors: Front: 203mm, Rear: 180mm
* Front Derailleur: Shimano Direct Mount SLX
* Rear Derailleur: Shimano Saint M810 GS
* Cassette: Shimano XTR 11x32T
* Crank: Race Face Altas FR 24x36T - 175mm
* Cainguide: MRP LRP ISCG w/party crasher lite bash guard
* Tires: Bontrager FR-4 26 x 2.35" tubeless ready
* Stem: Bontrager Big Earl 70mm
* Bar: Bontrager Rhythm
* Seatpost: Bontrager Rhythm Elite 31.6
* Seat: Bontrager Rhythm
* Pedals: Bontrager Big Earl
* Weight: 34.5 lbs as shown
Post a reply to: 2010 Trek Scratch Coil
