Chico, CA
8/16/2014 8:05pm
2010 GT force . Upgrades, Joplin seat post, Rear shock has been pushed.
$1900 OBO
Be glad to send pictures
SPECS:
Recommended Use: Crushing climbs, enjoying the varied face of Earth
Weight: 27.9 lbs. (Medium frame without pedals/reflectors)Dimensions: Frame Sizes: MediumMaterial: CarbonBottom Bracket Compatibility : 68mm EnglishBottom Bracket: Shimano XT OutboardBrakes: FRONT BRAKE: Shimano XT Disc, 180mm rotor REAR BRAKE: Shimano XT Disc 160mm rotorBrake Type: Shimano XT DiscBrakes Levers: Shimano XT HydraulicBrake Mount: DiscBrake Mount Type: DiscCassette: Shimano XT 11-34t, 9-SpeedChain: HG-73 9-SpeedChainrings: 22/32/44TCrankset: Shimano XT FC-M770 Hollowtech 2 44/32/22Crank Arm Length: Small 170, Med - XL 175Crank Bolt Pattern: 4-BoltFrame: GT designed carbon monocoque frame with Independent Drivetrain suspension. 6.0 inches of rear wheel travel. With forged I-link, standardized bearings and modular dropout system.Frame Material: Carbon monocoqueFork: Fox TALAS 32 R with QR 15 through axle system adjustable travel from 110 - 150mm with air spring pressure and rebound adjust with 7050 aluminum steererFrame Travel: 150mmRear Shock: Fox Float RP23 Shock/ This has been sent to Push and re-valvedFront Derailleur: Shimano XTFront Derailleur Clamp/Brazeon: ClampFront Derailleur Clamp Diameter: 31.8mmFront Derailleur Compatibility: TripleFront Derailleur Type: TripleHandlebar: Ritchey Pro Rizer Alloy 31.8 clamp, low riseHandlebar Grips: GT Lock Down, co molded locking grip system with alloy collarsHandlebar Material: AluminumHandlebar Width: 620mm (All frame sizes)Headset: FSA integrated sealed bearingHeadset Diameter: 1 1/8"Headset Type: InternalHub: FRONT HUB: Shimano XT centerlock disc for 15 mm through axle system REAR HUB: Shimano XT Centerlock DiscHub Spacing : 135/100Pedals: PEDALS NOT INCLUDEDPivot: Independent DriveRear Derailleur: Shimano Shadow XTRear Derailleur Cage Length: LongRear Derailleur Speed: 9 SpeedRear Shock Spring: Fox Float RP23 ShockSaddle: FIZIK Gobi XM with manganese railsSeatpost : Crank Brother dropper seat post with remoteSeat Collar: Aluminum 32.8mmSeat Collar Diameter: 32.8mmSeatpost Diameter: 31.6mmSeatpost Material: AluminumSeatpost Length: 367mmShift Lever Material: ResinShifters: Shimano XTSpeeds: 27 Total SpeedsStem: Thomson Elite X4Steerer Material: 7050 AluminumSuspension System: Fox Talas 32 R front suspensionStem Material: AluminumStem Clamp Diameter: 31.8mmRotor: Shimano XT 180/160Rotor Diameter : F 180, R 160Tires: Front: 26"x 2.3 Kenda Nevegal, 120 tpi with Kevlar bead, Rear: same only 2.1Tire Bead: Kevlar beadTire Size: Front: 26"x 2.3, Rear: 26"x 2.1Tubes: 26 x 2.1"Valve Stem Length: 26mmWheelset: RIMS: Mavic XM-719 DISC, welded with stainless steel eyelets. FRONT HUB: Shimano XT centerlock disc for 15 mm through axle system REAR HUB: Shimano XT Centerlock DiscWheel Size: 26"Wheel Axle Type: Quick Release
http://www.youtube.com/watch?v=lYlAb05U6dU
$1900 OBO
SPECS:
Post a reply to: 2010 GT Force Medium
