Mongoose xr 75 supension help
SOCAL_MTB
Calabasas, CA US
Edited Date/Time 8/16/2014 10:48pm
So i was given a Mongoose XR 75 for my birthday and it has a element racing fork/suspension and I wish it could be easier to compress the shock and I was wondering how to do that. It doesn't have any knob or adjusters on top of the fork.
thank you in advance
6/22/2012 8:45am
I'm afraid to say that nobody has been answering this post because there's most likely no help for that suspension. By "Compress the shock" I assume that you mean the rear. To make it compress more easily you'd have to either replace the spring with a softer one, if they are available. Or if it is the damping circuit, either change the shim stack, or more likely on a shock like that, drill out the compression circuit holes. But I'm not sure if you'd be able to find a shop willing to work on it.
Post a reply to: Mongoose xr 75 supension help
