Scott 700 Tuned Plus Spark £4900 UK
EB13
Edited Date/Time 9/2/2018 1:06pm
selling my Scott Spark 700 Tuned Plus bike Medium 2017 model bike is in mint condition serviced And ready to go has the usual marks like any used mountain bike.
This bike is the real deal they just don’t get any better then this google it check the reviews 5/5 every time,can also run 29er wheels see description below more photos on request PM any questions
Spark Plus Carbon / IMP technology / HMX BB92 / Carbon SMC Link / Carbon Plus swingarm SW dropouts for Boost 148x12mm / custom Chainguide
Rear Shock FOX NUDE Trunnion SCOTT custom w. travel / geo adj. 3 modes: Lockout - Traction Control -Descend DPS / EVOL / Kashima / Reb. Adj. Travel 120 - 85 - Lockout / 165X45mm
Fork FOX 34 Float Factory Air / Kashima FIT4 3-Modes with low speed adj. / 15x110mm QR axle tapered steerer / Reb. Adj. / Lockout / 130mm travel
Rear Derailleur Sram XX1 / Eagle 12 Speed
Number of Gears 12
Shifters Sram XX1 Trigger
Chain set Sram XX1 Eagle GXP Boost PF Carbon crankarm QF 168 / 32T
Chain Guide SCOTT Chainguide
Bottom Bracket Sram GXP PF integrated / shell 41x92mm
Cassette Sram XX1 / XG1299 / 10-50T
Chain Sram PCXX1 Eagle
Brakeset Sram Level Ultimate Disc 180mm F & R / Centerline CLX Rotor
Handlebars Syncros FL1.0 Carbon mini Riser 12mm rise / 9° / 760mm
Stem Syncros / 700 Series: FL1.5 +6° / 900 Series: XR1.5 -8° Integrated Spacer & Top Cup / 2014 Alloy / 31.8mm / 1 1/8" Garmin mount
Headset Syncros FL1.5 Drop in / Tapered 1.5" - 1 1/8" Ti bearing diameter size 42mm and 52mm
Grips Syncros Pro lock-on grips
Rims Syncros TR1.5 Plus / 28H / 35mm Tubeless ready
Front Hub Syncros TR1.5 Plus CL / 15x110mm made by DT Swiss
Rear Hub Syncros TR1.5 CL / Boost 148x12mm RWS w/removable Lever / 36T Rachet System / XD made by DT Swiss
Tyres Schwalbe Rocket Ron EVO 29x2.25 127EPI Kevlar Bead / Tubeless Easy PaceStar compound
Saddle Syncros XM1.0 / Carbon rails
Seatpost Syncros FL1.0 SL Carbon 10mm offset / 31.6 x 400mm
Post a reply to: Scott 700 Tuned Plus Spark £4900 UK
