Hi,
we are a official partner from Antidote and a little Bikeshop in Germany.
We offer you a Carbon Jack Frame in Sky Blue which is limited for 99 pieces. The Carbon Jack is handcrafted in Poland.
Equipped with 160mm travel, slack geometry and short rear Carbonjack gives the rider perfect balance while blasting down the trails. An upright seat tube angle and pedal efficient suspension makes climbing easy, giving you even more energy for fun parts!
Combination of carbon and vectran gives it the best balance of stiffness, vibration absorption and durability.
We have stuck with our patented FDS suspension. No shock mounts in the front triangle or swingarm means better stress distribution.
A simple and effective suspension design with unique shock access combined with lightweight and aggressive geometry will improve your riding skills dramatically, before you realize it!
Is it possible to buy the frame only or with a ccdb air/coil cs for 400$ additional.
Specs:
WHEELS: 650B / 27,5”
TRAVEL: 160mm
REAR SHOCK: 200/57mm
SEATPOST SIZE: 30.9mm (min. deep in frame 200mm)
REAR HUB: 142x12mm
BB: BB92 or 73mm
HEADSET: Semi-integrated 1 1/8” – 1,5” (Frustum ZS – 44,00mm x 55,95mm)
MATERIAL: Monocoque Carbon&Vectran Composite
BOLTS: Custom Alloy
LINKAGES: 7075 Anodized CNC
WEIGHT: 2.6 KG (M size)
FIRST OWNER RECEIVES LIFE LONG WARANTY
If there is any question send us a mail.
Your price: €3,150 EUR + shipping
Website: http://www.frameride.com
Post a reply to: Antidote Carbon Jack Sky Blue Enduro Frame limited Edition
