2014 Specialized Carbon Camber
Edited Date/Time 4/25/2016 6:06pm
Up for grabs is a, Size Medium, 2014 S-Works Camber 29er with carbon Roval Traverse SL 142+ Wheels!! 23lbs w/o pedals! Built bike in May 2015 rode it through November 1. Normal wear and tear. $4500
Bike is in Moab, Ut. Willing to sell Frame Separate if interested, $2000. Also have a non-carbon wheel set, lower price, if interested.
Pm with any questions, would love to chat.
Frame Specifics:
https://www.specialized.com/us/en/bike-archive/2014/camber/sworks-cambeā€¦
FRAME: FACT 11m carbon front triangle, 29" geometry, FACT IS construction, full FACT rear triangle, tapered headtube, carbon PF30 BB, full internal shift/brake/post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 110mm travel
REAR SHOCK: Custom FOX Float CTD Factory w/ AUTOSAG and Boost Valve, Kashima coating, Climb, Trail, Descend settings and reb adj., 197x48mm
FORK: RockShox Pike RC 29, Solo Air spring, tapered alloy steerer, comp, lockout, and reb adj., 15mm thru-axle, 120mm travel
HEADSET: 1-1/8 and 1-1/2" threadless, Hella Flush style upper with 1-1/2" lower, cartridge bearings
STEM: Truvativ 60mm, 4-bolt, 6-degree rise, 31.8mm clamp
HANDLEBARS: Truvativ Black Box carbon, 750mm wide
BRAKES: Sram Guide RSC w/ 160mm rotors
FRONT DERAILLEUR: Ain't got one!!!
REAR DERAILLEUR: SRAM X01, 11-speed, mid-cage
SHIFT LEVERS: SRAM X01, 11-speed, trigger
CASSETTE SRAM X01, 11-speed, 10-42
CHAIN: SRAM, 11-speed, hollow plates/pins, PowerLink
CRANKSET: SRAM XO carbon 175mm, PF30 spindle, removable spider
CHAINRINGS: 32T w/ bash guard
BOTTOM BRACKET SRAM PF30, OS press-in bearings, sealed cartridge
PEDALS: none
WHEELS: Roval Traverse carbon SL 142+ w/ DT Swiss 350 internals! Have a Roam 40 wheel-set, could part with frame, ridden for half of season.
TIRES: Conti Mountain King 2.4 Front, Conti Trail King 2.2 Rear
SEATPOST: Rockshox Reverb Stealth, 30.9mm, 125mm travel. Have a few different dropper posts I could part with frame.
Post a reply to: 2014 Specialized Carbon Camber
