2013 Intense uzzi vpp
Edited Date/Time 2/9/2015 2:58pm
Will sell with the Fork for $3200 Might consider Reasonable offers, Without fork for $2200 Might consider Reasonable offers
2013 Intense Uzzi, size Medium, flo yellow,
SPECS:
Frame: 2013 Intense Uzzi VP, 12x142mm dropouts
Fork: 2015 Un-ridden Boxxer RC, steerer tube un-cut
Headset: Cane Creek 40-Series ZS49/EC49
Rear Shock: 2015 Un-ridden Rockshox Kage RC
Wheels: Sun wringle Charger expert front, Charger Pro rear wheel
Tires: Maxxis DHF
Crankset: SRAM X9 22/33/Bash Ring
Bottom Bracket: SRAM GXP Team
Chain: SRAM PC 1031
Front Derailleur: SRAM X9 High Direct Mount, 2x10 (Currently set up 2x10 with bash ring, but can be set up 3x10 if requested)
Rear Derailleur: SRAM X9 10-speed Med Cage
Casette: SRAM PG 1030 11-36
Shifters: SRAM X9 Front, X7 rear
Handlebar: Truvativ Holzfeller 730mm length, 20mm rise
Stem: Bontrager Rythym Pro direct mount
Brakes: 2015 Un-Ridden Avid Code R, 4 piston Calipers, 200mm Front rotor, 180mm Rear rotor
Saddle: Velo Sacred Heart
Seatpost: Truvativ Stylo T30 31.6mm Black, 25mm offset,
Pedals:
Bike has had a full tune up, pivot service, and drivetrain clean and has not been ridden since.
Fork with un-cut steerer tube, Brakes, and Rear shock have never been ridden and are all 2015 year models.
Wheels are used, rear with a few dents and as true as possible, Front is completely fine.
very minimal scratching on frame, has never been crashed hard, only occasional slide outs
If interested in buying complete with fork I will have steerer tube cut to length and star nut installed professionally by a local shop.
I Might ship, I would just have to calculate shipping based on location then decide.
If i don't answer your call you can send me a txt or leave a message and I will get back to you as soon as I can.
Phone number: 480-223-2226
Post a reply to: 2013 Intense uzzi vpp
