Edgewater, CO
10/9/2017 2:03pm
Serviced and ready to go for the season.
January 2014- complete tear down and checked all bearings, re-torque and lock-tite all bolts.
Hand laced new Inferno 31 rims with all new DT spokes and brass nipples.
Brand new Kenda Excavator 2.5 front and rear.
New brake pads
October 2013- Fork seals and oil changed.
Current spec.
Frame: Voltage FR Alloy 6061, hydroformed tubing, Slopestyle & Park geometry, ISCG & ISCG05 tabs, headtube for 1.5“, IDS interchangeable Dropout with 12mm thru axle, 160 - 180mm travel
Fork: Fox 36 Van FIT RC2 coil, 180mm travel, coil spring, High/Low speed, preload, rebound adjustable, bottom out resistance in damper, 20mm QR thru axle, tapered steerer
Headset: FSA Gravity 2 tapered, upper alloy cups, 1.5“ Reducer to 11/8“, semi-integrated
Rear Derailleur: Sram X9, 10 Speed, short cage
Shifters: Sram X7, Trigger Shifter
Brake Levers: Avid Code R Disc
Brakes: Avid Code R Disc, 200/F and 200/R mm Rotor
Crankset: Truvativ Descendent DH 1.1, 165mm, 36T, alloy chainring
BB-Set: Truvativ GXP Cartridge, shell 73mm
Handlebar: Scott Pilot FR 1 Pro, D.B, 20mm rise, 750mm
Stem: Truvativ Hussefelt OS, 1 1/8“, 0° angle, 40mm ext.
Pedals: Wellgo B155U SCT, Flatpedal w/replaceable pins
Seatpost: Scott DJ zero offset, 31.6mm
Seat: Scott Voltage FR cr-mo rails
Front Hub: Scott Pro 20mm thru axle
Rear Hub: Scott DHL-135, 12mm thru axle, 135mm wide
Chain: Sram CN-PC-1051 w/Pwr lock
Cassette: Sram CS PG-1050, 10 speed, 11-36 T
Spokes: DT Swiss Champion black 15G 1.8mm
Rims: Sun Ringle Inferno 31 (Hand laced this winter, 1 ride)
Tires: Kenda Excavator 2.5 Stick-E Rubber
Rear Shock: Fox DHX RC2 coil, Boost valve technology, Rebound adjustable, low-speed compression, Bottom out force resistance adjustable, coil spring preload
Weight: 16.70 kg / 36.78 lbs
New brake pads
Current spec.
Post a reply to: 2012 Scott Voltage FR 10 Large
