2012 Rocky Mountain Flatline Pro, Medium
mountainjoo
Tarzana, CA US
Edited Date/Time 8/15/2014 10:54pm
Selling my 2012 Rocky Mountain Flatline Pro, White/Blue, Size Medium. Details below:
Frame Material: RMB FORM 7005 aluminum
Suspension:LC2R (Low Center Counter Rotating)
Pivot Type:angular contact cartridge bearing
Rear Travel:200 mm
Rear Shock:RockShox Vivid R2
Front Travel:200 mm
Rims:26 in DT Swiss E 540 tubeless compatible
HubsSad front) 20 x 110 mm WheelTech AM, (rear) 150 x 12 mm WheelTech DH
Spokes:DT Swiss ChampionRear DerailleurDizzy RAM X9 nine-speed
ShiftersDizzy RAM X7
CranksetDizzy RAM Descendant
Chain Rings:36 T
Crank Arm Length:165 mm
Bottom BracketDizzy RAM GXP
Chain Guide:MRP G2 Mini-G
Brake Levers:Avid Elixir 5
Brake Calipers:Avid Elixir 5
Front Rotor:200 mm
Rear Rotor:200 mm
Handlebar:Easton Vice
Handlebar Width:711 mm
Handlebar Rise:low
Grips:RMB lock-on
Stem:RMB DHR
Stem Length:40 mm
Stem Angle:10 deg
ChainDizzy RAM PC-951 9spd
CassetteDizzy RAM PC-951
Tires:Maxxis Minion DHF Super Tacky
Tire Size:26 in x 2.5 in
Valve StemDizzy chrader
SeatpostDizzy DG Micro I Beam
Seatpost Diameter:30.9 mm
SaddleDizzy DG I-Fly
Weekend rider, no racing done, do not do huge jumps or drops just little ones. Rode a couple of parks this summer. Upgraded the ff before riding the parks:
Brakes: AVID CODE R with 200 mm rotors front and back
Wheelset: Azonic Outlaws, White
Stem: Raceface Atlas
Bar: Azonic World Force, 30 in, 2 in rise, White
RFS: Starting a new project
Call or Text: 8184818150
Post a reply to: 2012 Rocky Mountain Flatline Pro, Medium
