2007 Custom Specialized Demo 8 Downhill Mountain Bike
DTDHLee
Lafayette, CO US
Edited Date/Time 5/31/2015 8:31am
Up for sale is an amazing custom built 2007 Specialized Demo 8! It's in great condition with no issues. The frame is a size medium and has 8" of suspension travel, front and rear and will fit most riders. It was purchased as built from the previous owner who had it built up from a 2007 Specialized Demo frame. It was built with good taste using some of the highest quality performance components. Hands down the best DH bike I've ridden with plenty of suspension adjustments to cater to different skill levels and techniques. Selling only for the reason that I need to save for tuition for next semester. Come check it out and be ready for this DH season! $1500 OBO, text seven two zero 903 59 seven 6
2007 Specialized Demo 8 Frame
All specs of the frame can be found at the link below:
http://service.specialized.com/collateral/ownersguide/new/assets/pdf/FS…
2006 Fox Shox RC2 40 Fork (Serviced may 2014)
• Travel: 8 in./203 mm, adjustable in ½-inch increments down to 6.5 in./165 mm
External Adjustments:
• Coil spring preload
• Rebound damping
• Low speed compression damping
• High speed compression damping
Internal Adjustments:
• Travel is internally adjustable down to 6 inches in half inch increments
• Bottom-out resistance
Fox Shox DHX 5.0 Rear Shock
• External Adjustments:
• Air spring pressure
• ProPedal
• Adjustable tuning range via schraeder
• Rebound damping
Shimano Hone Crankset with E-thirteen bash guard (2009)
26" Red Azonic Outlaw Wheelset (2011) Presta Valves
• Double-wall, welded, design rim with a wide profile for extra strength and rigidity
• 32 spoke construction for added strength and pedaling efficiency
• 6061-T6 Aluminum rim construction
• Front wheel converts from Q/R, 15mm & 20mm thru axles
• Comes with conversion kit
• 135mm & 150mm rear spacing
• Weight- 135: 2340g set, 150: 2362g set
• Weight:
135: 2340g (F 1080g + R 1260g)
150: 2362g (F 1080g + R 1282g)
• Joint: Welded
• Internal width: 25mm
• Valve hole diameter: 8.7mm
• Braking surface: DISC only
• Front hub shell: 2 cartridge bearings
• Front axle length: M5 QR
• 20mm axle adaptor (W/O through axle)
• Rear hub shell: 4 cartridge bearings
• Rear axle length: M5 QR
135: 12mm through axle
150: 12mm through axle
• Freehub material: Steel
• Bearings:
Size: 6804 Front, 6902 Rear
Width: 7mm
Diameter: Front ID 20mm / OD 32mm
Rear ID 15mm / OD 28mm
• Spokes:
Material: Stainless Steel
Number: 32
• Nipples:
Material: Brass
Compatability:
Tire: Pnuematic
Tire size: 1.9" ~ 2.25"
Avid CODE Hydrulic Disc Brakes with 200 mm Rotors (2014)
• Lever - Black Aluminum Lever, 3-cartridge Bearing lever pivot
• Caliper - 4-Piston, Dual-Diameter, Forged 2-piece
• Rotor -Centerline 200mm
• Pad -- Organic
• Fluid - DOT 5.1
• Adjustment - Contact Point Adjustment, Tool-Free Reach Adjustment, Adjustable Banjo, Tri-Align Caliper Positioning
RaceFace Diabolus DH Handlebar (2010)
• Width 710mm
• Rise 38.1mm
• Diamter 25.4mm and 31.8mm
• Bend 9º rearward, 4º upward
Shimano Deore XT M772 Rear Derailleur
• Shadow features a super low profile design that reduces the risk of damage from trail side hazards
• Single tension spring prevents contact with the chainstay resulting in a silent ride
• Direct cable routing prevents snagging from any trail side hazards
• All-alloy construction leads to lower weight without compromising strength and durability
• Four fluorine-coated link pin bushings make this one of the slickest shifting derailleurs on the trails
• High rigidity wide outer link braces the pulley body to increase pivot joint rigidity resulting in a crisp shift
• Strong return spring for a positive shifting feel
• GS cage should be used with single and double chainsets only
• Durable sealed bearing tension pulley
• Top normal spring for use with Rapidfire shifters
9 Speed Mountain bike spaced cassette (2010)
Crankbrothers 5050XX pedals
• Sealed bearings, low-profile design
• Each pair includes 36 short (3mm) traction pins pre-installed
Specialized Clutch Rear Tire 26x2.3 (New)
Specialized Butcher Front Tire 26x2.5 (75%)
DTDHLee
Lafayette, CO US
4/1/2015 9:24pm Edited Date/Time 4/1/2015 9:25pm
Post a reply to: 2007 Custom Specialized Demo 8 Downhill Mountain Bike
