the best cheap enduro bike
bbd
Edited Date/Time 8/27/2017 1:52am
i now own an all mountain bike and wanted to upgrade to a downhill bike but thought an enduro bike would be better as you can do a lot more diverse riding with it. any tips to help me buy the right bike would be much appreciated
the bike i want needs to be
-around 160mm of travel
-descends like a boss
-pedals uphill reasonably
-around 3k (Australian dollars)
-27.5
i thought of the giant reign, norco range but any experienced advice would be very helpful
i am most interested in this. can get it at 2950 AUd
i am most interested in this. can get it at 2950 AUD
cheers.
Falcon
Menifee, CA US
7/28/2016 5:24pm
I'm always looking in that "cheap but capable" range myself. So far, I like the Commencal stuff the best for that particular angle, at least here in the U.S., where they go consumer-direct.
Varaxis
Lake Elsinore, CA US
7/28/2016 6:27pm
Well, AU throws a wrench in anything I know. I'd be checking out the Giant Reign. Can probably talk them down to $3000 for the base model.
How much do the Canyon Strive and Whyte G160 run?
nickb01
NZ
7/28/2016 9:04pm
You're at a bad price point for what you seek, people ask a lot of Enduro bikes and at the cheaper price points for a new bike somethings gotta give. A friend bought one of those Norcos, and while the frame is good enough (apart from some squeeking from the linkage) it's an awkward mix of low end parts. Cheap brakes with 180mm discs paired with a 170mm fork? 1x10 speed, a cheap external dropper, cheap wheels and a cheap shock. You'd be much better off saving more and getting something that's got a much better package. For example
http://au.yt-industries.com/detail/index/sArticle/552/sCategory/342 - you can sometimes get good Outlet deals on these
or
https://www.bikeexchange.com.au/a/27-5-dual-suspension-mountain-bikes/t…
or at least for similar money, single ring one of these suckers:
https://www.bikeexchange.com.au/a/27-5-dual-suspension-mountain-bikes/g…
bbd
7/28/2016 11:28pm
is it possible to change it so there is internal cable routing for the dropper post?
RobJC
7/29/2016 2:13am Edited Date/Time 7/29/2016 2:15am
If you're comfortable with direct sales, I'd suggest a Vitus Sommet direct from CRC. $3000AUD gets componentry and frame, that on virtually all shop sold brands would cost nearly half as much again. I guess you'd have import duty to pay on this many dollars though?
Also, if you're a member of British Cycling (costs £20), you get a 10% discount code every month. Not sure it would work on an Australian CRC account though.
nickb01
NZ
7/30/2016 12:18am
Depending on your size RobJC could be right, if I had a budget of $3000k AUD I'd probably go with this:
http://www.chainreactioncycles.com/nz/en/vitus-bikes-sommet-suspension-…
and spend the remaining balance after tax and fees on a set of better brakes (SLX is good for a budget, Guide R good for power). If you're after an great descender it's worth having an excellent non-lockout shock, rather than a crap lock-out shock. I've got a non-lockout Float X2 on my Capra and don't even notice anymore.
liquidSpin
Alexandria, VA US
8/7/2016 8:28pm
Damn, how times have changed. When we think $3,000 is cheap or rather $3k is a lot but it won't get you much. Spend an extra 2-3k more you got yourself a proper bike. Spend over 6k and you got yourself an elite level bike.
....still can't believe it.
UpDawg
MX
8/8/2016 8:26pm
Let's back up a bit....
What is your current "all mountain" bike?
Post a reply to: the best cheap enduro bike
