CO
8/18/2014 11:10am
I finally finished my project bike... it rides pretty good!
The bike uses an 8-speed Shimano Alfine geared hub fit in between 83mm shell Saint cranks, a 20mm through axle front wheel as the rear wheel and tomicogs on the brake side of the hubs to drive the left side chain.
Geometry:
HA 64*
SA 75*
WB 46.5"
BB 13.5"
CS 17.3"
Weight: 44-45 lbs (using a bathroom scale)
more info and pictures here
Geometry:
HA 64*
SA 75*
WB 46.5"
BB 13.5"
CS 17.3"
Hell yes. Great work man, I'm really impressed.
-Not yet; the disc is in direct contact with the hub flange, so it should be good, and I haven't had any issues with the cog bending bolts or anything.
Quote: any advantage or disadvantage to using a 110mm wide hub on the rear?
-The advantages are that it is more narrow and won't catch rocks etc, it is light, and it is easily available (rather than go custom)... disadvantages being narrower spoke flanges, but the wheel is dished to be centered between hub flanges, so it should be plenty strong.
Quote: Thing is rad. Taking orders yet?!?!!!!
- thanks, but no. Hell no.
Quote: Worried about brake contamination from your chain lube?
-Yes. I just make sure to wipe off excess, and haven't had any issues yet.
-KT
Can you include a couple close-up shots of the moving bits of the bike (drivetrain front to back)? I would love to see more detail...
Post a reply to: new home-made gearbox bike thing
