My 6fattie sworks enduro!
ktg290
Ben Lomond, CA US
Edited Date/Time 12/14/2015 3:08pm
So I converted my 29er to a 6fattie.. Why? Because change is a constant in this industry and I have been doing the "bike thing" for over 12 years and get excited to try new things. First impression was that if feels like a heavy 29er with insane traction. I find I can carry more speed into corners and brake later thanks to the giant tire, feels ALOT more stable on blown out downhill trails (loose, holes, rocks get eaten up). On day 1 I ran no chainguide and the chain would get sucked into the wheel by the tire, I threw on a chai guide and it solved that problem, the rear tire DOES rub but switching from a 3.0 tire to a 2.8 will solve this, fork doesn't rub unless I run a fender. I'm a Santa Cruz local from Felton and I ride UCSC laps Monday through Friday, didn't have a single issue on yesterday's ride, overall I'm pleased with the conversion but the rotational weight is noticed obviously.
66th
10/24/2015 8:11pm Edited Date/Time 10/24/2015 8:11pm
that's rad. did all measurements/geo basically stay the same? if you run 2.8's are they a little smaller diameter?
we've got a vid w/ ropelato on his 6fattie dropping this week. he mobs it.
JCL
10/24/2015 10:00pm
Specialized need to make 2.8" and 3.0" Grid casing Butchers. Weight be damned!
lev
Leighton Buzzard GB
952nd
10/25/2015 12:23am
That's a lot of squish with even more squish! Do you think it would feel better with less travel?
10/25/2015 1:57am
ktg290 wrote:
[img]https://p.vitalmtb.com/photos/forums/2015/10/24/2596/s1200_image.jpg[/img] So I converted my 29er to a 6fattie.. Why? Because change is a constant in this industry and I have been doing the "bike thing"...
Please put some more photos of that awesome bike
THANKS Smile
ScotCove
10/25/2015 5:53am Edited Date/Time 11/10/2015 12:07pm
It looks great,no doubt and would be a hell of a lot of fun.To hell with weight issues unless you are a serious contender in races.
But I would have to ask you why you put a 3 " on the back,when the general consensus is always to put a smaller width on the rear ?
That's ok if you run 2.35's or 2.4's because you know you will get good clearance either way.
Now you are left with unecessary rub marks on your frame.
Don't take that the wrong way,but check before you commit.
Love the bike though
mp
10/25/2015 6:23am
Newschool double wides and 3.0 Gazzas! Ha!
ScotCove
10/25/2015 6:31am
I really want to try Nokian Gazza's so much.
There is a pair for 40 GBP going,got to get them
ktg290
Ben Lomond, CA US
10/25/2015 1:36pm
that's rad. did all measurements/geo basically stay the same? if you run 2.8's are they a little smaller diameter? we've got a vid w/ ropelato on...
It feels slightly slower but I haven't done any measurements. Tire only rubs when I send it. I hope maxxis makes some fatty tires for it, rear tire already has some punctures in the side wall after two rides
ktg290
Ben Lomond, CA US
10/25/2015 1:38pm
ScotCove wrote:
It looks great,no doubt and would be a hell of a lot of fun.To hell with weight issues unless you are a serious contender in races...
Specialized only makes a 3.0 for now in the purgatory, I'm going to look into wtb for a smaller rear tire
4173rd
10/25/2015 2:01pm
Here's a similar conversion in action:
Lots of tire roll in the turns. Same experience for you?
AGR97
10/25/2015 2:15pm
This is my main concern with these mid fat bikes, is it an issue when cornering hard?
ktg290
Ben Lomond, CA US
10/25/2015 5:14pm
I only experienced tire roll when running under 15 psi..
10/25/2015 6:00pm
Skidding through berms is rude. Or was that the tire roll?
ScotCove
10/25/2015 6:41pm
Vittoria tyres are of a slimmer profile if you want to have a look at them.
Jafaki are a great tyre.
2.5 though,would you run it that "slim"
kidwoo
Grass Hut, FM US
10/25/2015 8:05pm
It's like riding on a year's worth of farts.
SomisMoto
Somis, CA US
10/25/2015 8:12pm
Dang. My dad has an Enduro 29 Comp and I might just look into doing this.
I would definitely have to go 1x10 because the current 2x10 doesn't even leave clearance for 2.35 Schwalbes.
Just to clarify, you're running 2.8 in the rear and a 3.0 up front?
Pukwudgee
Brewster, MA US
10/26/2015 6:32am
I've been thinking about doing the same with my Enduro 29. Is it significantly heavier? Did you spring for the Traverse Carbon wheels, or aluminum? Tubes or Tubeless? I'd like to hear what your impressions are on other tires, I'd like a smaller tread (even like a Renegade) but keep a tough casing...
jspec29
Portland, OR US
10/26/2015 8:56am
I switched to a Fox 36 looks like it might have less clearance then a pike for a 3.0 tire. Anyone try this conversion with a fox instead of pike?
Jukulae
NV US
10/26/2015 9:59am
KTG290,
I just went to Santa Cruz for the first time and I love your local trails around UCSC.
I have been thinking of doing this on my Enduro 29er as I live in a Yucca Valley, Ca where the trails are very sandy. Actually there are no MTB trails, I just ride the dirt bike trails. I figured having a bigger foot print will make the trails just a bit more enjoyable. A fat bike is out of the question. I will get a dirt bike before I do that. Do you think its worth the investment to ride sandy trail conditions?
How do you like the ohlins??
ktg290
Ben Lomond, CA US
10/26/2015 12:18pm
I'm running tubeless 3.0 tires front/rear and carbon roval traverse fatty wheels. Really disappointed with the control casing by the way, just isn't holding up on the rough stuff... Worth the money??? I'm not sure, my old setup worked just fine but the extra traction is amazing. And yes it feels much heavier. And do answer the ohlins question... It Feels much more dh oriented, and no climb switch is rough at first but I don't really miss it
stiingya
Albuquerque, NM US
10/27/2015 10:41pm
I like how he switches to the DH helmet when the terrain is all open and grassy and he's not even going as fast, just air time. But when he's in tight, twisty trails with trees all around waiting to smack into, AND absolutely FLYING! no DH helment then... Smile
10/29/2015 3:17am
Please correct me if I am wrong if I have 2 enduros a 29er and a 650b it would be just matter of putting some 2,8/3,0 tyres on the 650b roval traverse fatty rims and mounting them on the enduro 29" ?? No need for other changes?
jspec29
Portland, OR US
10/29/2015 3:54am
Please correct me if I am wrong if I have 2 enduros a 29er and a 650b it would be just matter of putting some 2,8/3,0...
Yes that's it!
ktg290
Ben Lomond, CA US
10/30/2015 11:29am
And she weighs 30.5 pounds, not too bad
12/14/2015 3:08pm
jspec29 wrote:
[img]https://p.vitalmtb.com/photos/forums/2015/11/12/2673/s1200_20151112_132937.jpg[/img] [img]https://p.vitalmtb.com/photos/forums/2015/11/12/2674/s1200_20151112_132913.jpg[/img]
Which WTB tyres are these?
Post a reply to: My 6fattie sworks enduro!
